Peter Wilson
- Oct 11, 2013
- Newcastle upon Tyne
- United Kingdom
- Mini 0801 DashCam and Blackvue DR550GW, iPhone 4S.
Well I am hoping for the following.
Let me choose what Bitrate front and rear cameras can run at, (a warning if they want that the machine may get hot if the bitrate is increased). My front camera is only running at 20-30 oC on 24 hours and the rear is running at 25-30 oC same. So they can both handle a bit more kBps
Choose how long before the camera goes into parking mode.
Let me choose the colour of the front LED.
Let me choose Compression High Medium Low None.
It would be Better if they had allowed the WiFi to connect to your home network (using the settings to set the name and password of your router) this would make it so that when you park on your drive you can access via blackvue and save on the laptop. I am sure this can be done.
The last thing is to get the memory card out you have to switch off and wait then disconnect the power then the (Sensitive) rear camera wire then move the cover and push the card in and remove. Now considering the rear cameras cables have had to be redesigned because the slightest bad connection they go out it not advised to keep pulling the cable out. I have left the cover hanging down as I like to back up every night and keep a record just in case I get a parking van ticket or notice a couple of days later that there's a scuff on my bumper. The Memory card should be under a cover on the left of the camera.
Anyway anyone else have any ideas as to how they can improve the next gen Please post it here.
Peter. PS Since I have had the camera Not one person has cut me up or pulled out in front of my 4x4. LOL typical as it was happening every other day before.
