Mine should arrive next week. It will be the updated version. I will post here when I get it.Evan55 said:so has anyone gotten the new version in to fully test it out and run it for a few days?
about to pull the trigger but I want to be sure there are no issues with the new version
irononreverse said:I just got mine. Firmware 20130604. Haven't installed it in my car yet but noticed the file extension is .TS so RegistratorViewer can't open it natively.
jokiin said:there's some issues with the MOV version of the firmware, the TS version doesn't have the stability problems so a bit annoying as far as playback goes but far more reliable
newalias said:jokiin said:there's some issues with the MOV version of the firmware, the TS version doesn't have the stability problems so a bit annoying as far as playback goes but far more reliable
Does using TS have impact on file size? I can imagine MPEG2 TS files are larger than MOV? Thanks.
irononreverse said:A stationary 3 minute clip is about 230mb for me. Battery lasted about 40 minutes.
jokiin, do you have a custom sample from the factory, or made a custom FW version?jokiin said:depends on the bitrate what size the files will be, the one I have here is set to 15Mbit so the files are a bit bigger, they're in line with my other cameras at the same bitrate though when using MOV or MP4 output
ciuvak said:jokiin, do you have a custom sample from the factory, or made a custom FW version?jokiin said:depends on the bitrate what size the files will be, the one I have here is set to 15Mbit so the files are a bit bigger, they're in line with my other cameras at the same bitrate though when using MOV or MP4 output
how did you get it? 🙂jokiin said:both, spec and firmware is different
ciuvak said:how did you get it? 🙂jokiin said:both, spec and firmware is different
So you are saying there are multiple versions of this camera? What specs does yours have?jokiin said:drove to the factory and picked it up
ciuvak said:So you are saying there are multiple versions of this camera? What specs does yours have?jokiin said:drove to the factory and picked it up
Alright, so besides the A2S60 + OV2710 combo, what else is out there? Is your config the best possible variation of this model? Could you please share more detailed specs? This could help others to ask the right questions when ordering from a seller.jokiin said:There are 3 different factories doing this model currently, the main board and housing all come from the same factory though, spec level is up to the supplier/customer, there's a few different options available for lens, sensor, memory and GPS
ciuvak said:Alright, so besides the A2S60 + OV2710 combo, what else is out there? Is your config the best possible variation of this model? Could you please share more detailed specs? This could help others to ask the right questions when ordering from a seller.jokiin said:There are 3 different factories doing this model currently, the main board and housing all come from the same factory though, spec level is up to the supplier/customer, there's a few different options available for lens, sensor, memory and GPS
jokiin said:irononreverse said:A stationary 3 minute clip is about 230mb for me. Battery lasted about 40 minutes.
irononreverse said:jokiin said:irononreverse said:A stationary 3 minute clip is about 230mb for me. Battery lasted about 40 minutes.
How did you change the bitrate or are you talking about your own cust
what is the limit of bitrate for A2S70? is it possible to tune it up to 20Mbit/s? I have now GS9000 and bitrate is 13-14Mbit/s, but I still see compressing artifacts.jokiin said:I have a different firmware on it at the moment to test at 15Mbit so I could compare to our other product, makes for a fairer comparison if they are both set to the same bitrate
