airbender
- Mar 24, 2013
After I gave up on BlackVue DR500GW-HD as the video quality was sub par I researched a little bit more and decided to try the DOD LS300W.
It does seem to have wider angle of 140 degrees, not as much as BlackVue DR500GW-HD but slightly better than the 120 degrees of most DVRs. 140 degrees may help get a little bit more visibility when cornering.
I also thought about the DOD VRH3 as they are advertising 160 degrees view however some sites still quote 120 degrees and the sample videos certainly don't look like 160 degrees. I am not sure it is 160 degrees. If so you would expect it would look wider angle than DR500GW-HD. It does not.
http://www.dod-tec.com/product.php?cat_1st=4&cat_2nd=35
I just ordered it along with the 3M mount accessory from their Canadian website:
http://www.dod-tech.ca
Though pricier than the other Chinese websites I can rest assured that I am buying original.
This one does not have GPS, I am not too interested in GPS, however the night time quality in sample videos is very good.
I will post once I receive the device and see how it works. Wish me luck !
