The Chupad D501 is a wedge shaped camera made in China released in the second half of 2016. This is the first camera we have seen from the Chinese manufacturer Chupad. The D501 is based on the Novatek NT96658 processor and Sony Exmor IMX322 CMOS sensor. Currently this is one of the lowest priced dash cams with a Sony CMOS sensor.
The maximum resolution of the camera is 1080p at 30fps and it records with a bit rate of approximately 12Mbps. What is impressive on this camera is the video quality. Video quality during the day is very good and night quality is good. For less than $60, the D501 has arguably the best video quality at this price point.
Another surprising feature of this camera is that it comes with WiFi (Finalcam iOS / Android app), which is quite rare at this price point. It comes with a 2.45″ screen and G-Sensor but it does not come with GPS. No parking mode is available and be sure to turn off motion detection since it does not work well with this camera. Build quality is quite good and the size is reasonable at 83mm x 66mm x 35mm. The wedge shape allows it to be mounted discreetly as well. One unfortunate aspect of the design is the chrome ring around the lens and around the mid section of the camera. We would prefer a fully black camera to make it more discreet.
While this camera has many positives, you should be aware of the negatives as well:
- No ability to turn off the LCD screen automatically via the settings (can be turned off manually by quickly pressing the power button or holding down M button)
- No audible warnings when microSD card is not inserted
- No firmware updates / limited support from the manufacturer (have not seen any firmware updates or manufacturer support)
- 180mAh battery instead of a super capacitor is not ideal for hot climates
Our members Sunny and Agie provided detailed reviews of the Chupad D501 on our forum. Sunny also created the following unboxing video with video clips as well.
Wifi App Freezes Camera
Some owners have indicated that the Finalcam app can occasionally freeze the camera. You will need to reset the camera via the pinhole reset button. There appears to be more issues with the Android app depending on what smart phone you are using. There is no known solution to this problem.
Agie provided this photo comparing the A119 on the right with the D501 on the left mounted in a car.
If your 2 main criteria for purchasing a camera are best video quality for the lowest price, the Chupad D501 is very difficult to beat. The video quality is some of the best for the lower than $60 price point and having WiFi as well is a great deal. Initial reliability also appears to be good. That being said, there are a number of drawbacks to consider (no GPS, limited / no manufacturer support, LCD screen does not automatically turn off, chrome highlights, battery based camera).
If you can live with the drawbacks, the D501 is a good choice on a budget. If the drawbacks are a showstopper for you, the VIOFO A119 may be a better choice for a few more dollars. You can read what other owners of the camera have to say on our Chupad forum.
We have not been able to source any firmware for this camera.
Spec Chupad D501 Brand Chupad Model D501 Channels 1 Channel Setup Front Form Factor Wedge Release Date Aug 2016 Country China Warranty 12 months Spec Chupad D501 Processor Novatek NT96658 Video Format MOV Compression H.264 Screen Size 2.45" Touchscreen No Mount Adhesive Power Supply 5V Battery Type 180mAh Spec Chupad D501 Parking Mode No Wi-Fi Yes GPS No Apps Android, iOS Cloud Connectivity No Voice Commands No Spec Chupad D501 SD Card Type MicroSD Max Card Size 32GB Operating Temperature -10°C to 65°C Swivel No Error Notification No Camera Units
CMOS Sony Exmor IMX322 Max Resolution 1920 x 1080p FPS 30 Bitrate 12.0 Mbps Viewing Angle 170° Dimensions 83 x 66 x 35 HDR No Ratings
Published: Feb 22, 2017
