The FineVu CR-2000G is a dual channel dash cam that records 1080p at 30fps for both the front and rear cameras. Like most of the dual 1080p cameras released to date from Korea it has a large front camera with a touch screen and a smaller cube styled rear camera.
This dash cam has built in GPS, G-sensor, lane departure warning system and parking mode. The FineVu CR-2000G also has dual card slots (1 micro SD and 1 standard SD). The camera is apparently using an Ambarella A7 processor and and a 2.4 MP Sony Exmor CMOS sensor. Overall video quality is very good during the day and average at night.
The biggest drawback with this camera is the form factor. The front camera has a 3.5″ screen and is 92.5mm x 66mm x 42mm, a bit on the large size. The flashing orange ring around the lens does not help with discreetness either. The rear camera is cube shaped at 35.8mm x 35.8mm x 35.8mm. While much smaller, the cable connects from the top and using the standard mount, it is difficult to install near the top of a rear window. So even though the camera is quite small it is quite noticeable when installed on the rear window.
We would like to thank our member, USDashCamera, who did a review of the FineVu CR-2000G in the following video.
FineVu CR-2000 Series
FineVu has created a number of cameras under the CR-2000 series with a similar form factor but slightly different specifications. They are as follows:
FineVu CR-2000R
- 1080p Front Camera
- 720p Rear Camera
- Sony Exmor CMOS Front only
- External GPS Optional
FineVu CR-2000R WiFi
- 720p Rear Camera
- Sony Exmor CMOS Front Only
- WiFi SD card provided
FineVu CR-2000S
- 1080p Rear Camera
- Sony Exmor CMOS Front and Rear
FineVu CR-2000G
- 1080p Rear Camera
- Built-in GPS
- Lane Departure Warning System
FineVu CR-2000 Omega
- 1080p Rear Camera
- External OBD-II Optional
- Forward Collision Warning System
Since this camera has just been released, there have not been any reported problems yet.
The FineVu CR-2000G is one of the best dual cameras available today. The form factor for both the front and rear cameras is disappointing and the $400 price tag is a bit steep. That being said, FineVu makes high quality cameras so if you are looking for a dual 1080p camera this should be a consideration. Take a look at the BlackVue DR750LW-CH and Panorama X2 as well.
Firmware is only provided via the sellers of this camera.
Spec FineVu CR-2000G Brand FineVu Model CR-2000G Channels 2 Channel Setup Front, Rear Form Factor Hanging Release Date Sep 2014 Country Korea Warranty 12 months Spec FineVu CR-2000G Processor Ambarella A7 Video Format AVI Compression H.264 Screen Size 3.5" Touchscreen No Mount Adhesive Power Supply 12V Battery Type Capacitor Spec FineVu CR-2000G Parking Mode Buffered Wi-Fi No GPS Yes Apps Windows Cloud Connectivity No Voice Commands No Spec FineVu CR-2000G SD Card Type MicroSD, SD Max Card Size 128GB + 128GB Operating Temperature -10°C to 60°C Swivel No Error Notification No Camera Units
CMOS Sony Exmor Max Resolution 1920 x 1080p FPS 30 Viewing Angle 136° Dimensions 92 x 66 x 42 HDR No CMOS Unknown Max Resolution 1920 x 1080p FPS 30 Viewing Angle 136° Dimensions 35 x 35 x 35 HDR No Ratings
Published: January 23, 2015
