Sunny
- May 31, 2014
- Colorado
- United States
- More than I can review. ;)
@GearBest provided this dashcam for review.
Thank you!
It's on sale at gearbest.com for $99 with coupon code: GDR33
You have to login to use the coupon code.
Main Features:
2.3 inch TFT screen display
Supporting micro SD card for external storage, up to 32GB capacity (micro SD card not included in the package)
Supporting G-sensor
110 degree wide angle
Supporting PC TOOL image file management software (Software not installed in the product)
Built-in speaker and microphone
Built-in 930mAh rechargeable battery, car charger with mini USB port
Supporting video recording, taking photos
I read few comments in Amazon that it doesn't have GPS but the Garmin's site describes GPS in this model so that's something I'll check out:
http://www.garmin.com.sg/products/ontheroad/gdr33/#featureTab
http://www.garmin.com.sg/products/ontheroad/gdr33/#funcTab
GDR 33 Specifications:
Dimensions: 8.19 × 6.57 × 4.16 cm (L x W x D)
Weight: 122g
GPS Yes
Screen: 2.3" TFT LCD
Camera: f/2.0
Shooting range: Horizontal viewing angle at 110 degrees
Photosensitive components: 3M, 1/3", CMOS
Frame rate: 30 FPS
Video format: AVI (H.264 compression technology)
Gravity sensor: Yes, with collision sensitivity settings
Built-in battery: Yes
Microphone: Yes
Speaker: Yes
Memory card slot: microSDHC, a 8GB Class6 memory card above is recommended
Recording mode: Non-stop recording; when the card is full, old files overwritten (except those being protected)
■ 1080p (1920 × 1080 pixels) at 30fps, save about 1.86 hours in a 8GB micro SD card (256MB for each video file)
■ 720p (1280 × 720 pixels) at 30fps, save about 4.13 hours in a 8GB micro SD card (256MB for each video file)
■ WVGA (848 × 480 pixels) at 30fps, save about 9 hours in a 8GB micro SD card (256MB for each video file)
Ambient temperature: 0 to 70 degrees Celsius
Overall Conclusion:
Video: Default setting is little underexposed so need to up the EV little bit.
At 9mbps, it has pretty good daytime video quality.
Night doesn't have a lot of sharpness but more areas are visible so it's decent.
Audio is very good.
Detailed review:
Package contents:
It comes in a nicely printed box with the following contents:
1. Garmin GDR33 Dashcam.
2. Sticky ball mount.
3. mini USB Car charger.
4. Extra tape for the mount.
5. Inspection sheets.
6. Product manual (in Chinese).
Physically, it feels very well built.
Front has embossed GARMIN label and GDR33 written right below the lens.
Note: Most of the pictures are sid-by-side with Dome G90 and Hetai Nautilus Nemo's eye cameras.
Most of the buttons are below the 2.3" LCD screen and corresponding icons are displayed in the screen:
Right side looking from the back has mini USB port:
Left side from the back has power button and microSD slot.
Bottom has just the microphone hole.
Top has speaker vents and socket for ball mount.
The mount is pretty good made as well but it's long so overall camera hangs little bit below the rear view mirror.
Startup has Garmin logo splash followed by a nice warning about "Do not operate this device while driving...can result in death, serious injury..." so no pressing emergency button. 😉
LCD screen and resolution is of very high quality, it's like a cell phone screen, very smooth and clear.
Menu/settings are very clean unlike cheap dashcam menu that look like old dot matrix. 😀
Unboxing video:
Test videos and screenshots coming soon...
Thank you!
Main Features:
Supporting G-sensor
Weight: 122g
GPS Yes
Camera: f/2.0
Frame rate: 30 FPS
Microphone: Yes
Speaker: Yes
Overall Conclusion:
Audio is very good.
Detailed review:
Package contents:
Unboxing video:
