www.gibson99.com has everything I did including the install of the cf-100. I'm guessing that's what model you have. There is also a ch-100b which is completely different.I heard there was no or little G-Sensor sentivitity range. Or are you able to switch ?
Also, Gibson99 may I ask you a couple of other questions?
1. With the parking mode - I understand the ad card is partitioned to save space for events. When the Events partition is full will it loop record or do I have to do something else? What? Re-format the card? Thoughts?
2. Could you re-post your links re car installation AND the software workaround (is that what it is?)
3. Is there a workaround for separating the back and front videos using a Mac? VLC? Thoughts?
Thanks in advance. Most appreciated!
