Trying to install YiMax script, wifi light blinks for 15 minutes?
Trillion
Croatia
Xiaomi Yi 23L
Xiaomi Yi, Z23L, 1.2.13 firmware. Today I saw an article on hacking this camera, so given that I already had some experience with these things (on my Lumix DSLR) I gave it a try.
Formated the SD card, downloaded the 1080p60 version of YiMAX-PRO for 1.2.13 firmware, copied both files (autoexec and goprawn) on the card, booted up the camera. The wi-fi light started to blink (I would say at "half power" of its usual) and...it just blinks now. For 15, 20 minutes.
I googled and looked at some videos in order to find some answer, no luck - how long does this blinking have to go?
Also, what if I don't like the settings, how do I fall back to OEM bitrates? Thanks!
If you would read the read me file that came with it you would see that it says the WiFi light blinks endlessly to let you know the script is working.
If you don't like the YiMax script and want to remove it you just delete the 2 files from your SD card and you will be back to where you started.
