Your t5e cuts the videos automatically
pescasub29
Austria
Hi, I did battery life testing letting it burn until the end, it lasted a little over an hour at 1080p 60 fps, but my surprise was when I went to the gallery and watched several videos of about 20 minutes. I wonder if this is normal?
Taken from User Guide for Ambarella A12S Cams (See FAQ)
Download Guide LINK HERE
"The file system the camera uses is FAT32 and the maximum file size is 4GB. Your camera will split files into 4GB parts. The video length of each file will be determined by the resolution and fps you have set. Lower resolutions will result in longer files. "
Tried recording via Tablet using ThiEYE HD WiFi App so I could be ready, guitar plugged in and cranked up (all WiFi does is start recording process) and vids divided into 1.05min and 1.2min files? Well that has nothing to do with Windows 10 or FAT32 and lucky it was just a practice.
SHEESH
Why 1 minute files?
ThiEYE HD APP has been upgraded apparently. Will try it later.
