Hello,
I recently purchased a Viofo A118C2. Sometimes the date and time resets to 1/1/2016. If I turn the camera on/off after I set the correct time, the settings are saved. This seems to happen overnight. GPS is off also. The other settings are saved (e.g loop time, sensitivity and timezone), only date and time cause problems.
Usually I remove the sdcard when I go in house, can this cause the problem?
Another thing I noticed, when I stop the engine the camera turns off instantly, no splash screen or blinking led. Is this normal ?
Thanks!
Thanks!
