Is this water proof / resistance?
Hi Dellye.Is this water proof / resistance?
Me either. Have both the Virtoba and ThiEYE REMO style remotes. Tried with T5e and camera locked up and used the ThiEYE one to test BT connect. Took battery out to reset but still locked, No buttons worked. After a day or two thought to try again and came came good. I don't believe changing firmware to REMO works (not for me anyway). Virtoba worked with ThiEYE E7 cam OK though.Hello,
I have a t5e with lastest firmware for new REMO controll. I am not able pair my remote control from I make factory reset of camera, card format but I still cannot pair my remote. Thank you
Only seen with GoPro Hero 3 and 4 (Ambarella chipset) and they say HDMI cables? Seems strange using HDMI. INFO LINKis there a way to start recording on 6 t5 at the same time ? (git2 and yi4k both have usb/remote cable so a master camera can have 5 slaves and when you start recording on the master all slaves start at the same time ?) if not by cable is there a wifi/bluetooth tweak that let your smartphone start recording on multiple cameras a the same time ?
