E-PRANCE G1W - Which Firmware?
DJDunk
I have an e-prance G1W which I've had in the cupboard for a few years and just started using.
My issue is that it fills the memory card, displays "CARD FULL" and stops recording. I expect it to overwrite the oldest file.
I have loop recording 'off' and g-sensor 'off'.
I've tested it with loop recording on 5 mins but have the same issue.
Does anyone recommend a firmware that would resolve this?
loop recording off will always stop when the card is full, that's expected
with loop on you should be fine though, try reset all defaults and format the card and see if still an issue
Thank you, I'll give it another go. I had tried it on the maximum loop available (5 mins) with the same issue, but I'll give it another go.
try a different setting and see if it has issues, you might also want to try a different memory card as a test
