Vantrue E360 Dash Cam Firmware Update
yes, currently, we have two apps. The newer app supports dash cam with LTE functionality. However, we have a plan for next year to make the Vantrue Connected app compatible with all Vantrue Wi-Fi-enabled devices.
Very nice, just hoping it doesn't confuse new users that's all
Dumb question of the day - I do not have LTE module - what app should I use moving forward?
Since Vantrue Connected v1.0.8 seems to be newer, should we all stick to that app?
UPDATE: Vantrue Connected is definitely better written app.
- HDR timer menu option actually works
- Voice command menu actually list commands
My recommendation is keep it simple and for all E360 devices just recommend/use Vantrue Connected
I have to admit, when I loaded the Vantrue app on my iPhone I spent way too much time trying to understand if I wanted the Vantrue or Vantrue Connected app.
Descriptions for both apps say the exact same thing "Vantrue (or Vantrue Connected) is used to view the GPS route tracker captured by the Vantrue car driving recorder"
I would have expected the descriptions to say "Control the Vantrue dashcam and view live and recorded videos" and "Vantrue Connected adds LTE Module functionality".
What is the GPS route tracker and what does it have to do with the app?
GPS route tracker in the player and in the Vantrue application.
Definitely the faster of the two apps as well when loading
It just seems really odd that the description of this app only references a secondary or tertiary function (GPS route tracker) and not the primary functions which are to change dashcam settings and manage video files.
Vantrue E360 Dash Cam Firmware Update​
  • Release time: 2025-03-13 11:23:37
  • Version: E360_VT-EEC111
Major Updates:
1.Updated to the latest IQ, enhancing clarity.
2.Added PanoVis stitching mode. Panorama mode now supports center and left-right stitching, and the dual fisheye mode supports left-right and top-bottom stitching.
3.Added Traditional Chinese language support.
4.Introduced "Fatigue Driving Reminder" feature.
5.Introduced "Overspeed Reminder" feature.
6.Added feature for LTE module SD card upgrade, allowing firmware upgrades through the main unit.
7.Introduced SIM card data control feature.
8.Added APP key feature to prevent third-party apps from connecting to and operating Vantrue devices.
9.Added an infrared light option for parking monitor settings, allowing independent control of the infrared light in parking mode.
Other Updates:
1.Customer feedback issue: Enhanced the parking monitor feature to resolve occasional inability to exit parking monitor mode.
2.Resolved the issue where "4G SD card formatting doesn't notify the app upon completion, causing a status mismatch."
3.Improved connection stability and addressed issues with screen flicker and non-display for the rear camera.
4.Changed the default date to January 1, 2025.
5.Fixed the issue of abnormal display when enabling collision quick start mode and switching from fisheye view in Drive Record to handheld panoramic mode.
6.Resolved "visual anomalies in handheld mode when returning to the main screen."
7.Fixed the issue where "disconnecting the APP manually when viewing photos in the SD card album causes touch commands to be ineffective upon re-entering the album, preventing returning to the list view."
Too bad dashcam companies can't let you sign up for email or text alert when new Firmware is available.
Connect your smartphone/iPhone more often via the application with your models
and the application will notify you about the release of new firmware.
Firmware Update
Release time: 10/21/2025
Download
Version: E360_VT-EEJ101​
1. Resolved the problem where some units lost parameters after upgrading the firmware following successful assembly.
2. Certification update: Removed UKCA and PSE certifications.
3. Fixed the Russian translation for “Voice Recognition.”
4. Bug fix: Resolved an issue where the on-screen message occasionally failed to disappear when entering Motion Detection mode.
