egonvdv
- Aug 9, 2013
- A Dutchy in the South of France
- France
- TWO Blackvue Elite 10's (rear cams used as side cams)
I only noticed because the camera stopped giving voice messages (“Parking mode off”, etc.), because all 3 LEDs (REC/GPS/ACC) were on!
The manual recording button did not work, neither did Wi-Fi.
If I switched the camera off, it would immediately switch itself back on again.
Unplugging it completely from power did not help either. - It also seems the camera does not have a reset button...???
I then checked the footage.
It correctly stored the last image, then simply stopped working during a drive (so the last file was not corrupt).
The SD card was full, but of course the camera should automatically overwrite older footage.
I formatted the card with the PC software, and when I put it back into the camera, the camera formatted it again automatically.
After that, the camera started working again.
I'm on the latest firmware, updated about a week ago.
Has anyone had similar issues?
The only reason I had the sound enabled was because the camera is fairly new and I wanted to make sure everything was working properly.
If the sound had been off, I probably never would have noticed the camera had stopped working.
This absolutely makes me lose faith in it.
