0801 Time keeps changing randomly
johntee
Hi,
I've just updated my 0801 to Firmware "20140519" with the help of Tobi@s and the problems I had previously with the 0801 turning off have now been resolved. This new Firmware version are in German & English languages which are selectable.
However, since that update I'm having trouble getting my 0801 to retain the time which I put in the device via the 'Menu'. It changes the hour time randomly + the 'am' to 'pm' changes randomly too. The peculiar thing is the 'Date Stamp' always remains correct and places that info onto the video file, it's the hourly time that changes. I've tried setting everything to back to default settings via the Menu feature, but that makes no difference.
Can any member suggest a cause and hopefully a remedy.
Cheers,
John
Have you set the correct time zone?
Hi Tobi@s,
Wow, you've hit me in the lower regions with that one. Where exactly is that located within the menu??
I thought I'd read the pdf manual thoroughly, obviously I need new glasses or a rear end boot.
Cheers,
John
Hi jokiin,
I'll take a look with my magnifier glass, is the GMT time zone set to a "Zero" or similar,
Thanks for your reply and advice,
Cheers,
John in the UK
the default will probably vary according to which version it was and which market it was originally intended for, the generic ones are quite often set to +8 as that's the home timezone in Shenzhen where the developers are from
for UK you're wanting 0, or +1 if it's summertime if you're in an area that supports DST offsets
Hi jokiin,
Thanks again, I found the tiny little 'time zone', very easy to miss as you said. I've set it to "0" for the UK so everything should run smoothly now.
You may appreciate why I had to give up my job as a brain surgeon 🙂 🙂
Cheers,
John
