Hi
This forum seems to be the most knowledgeable on this cam (been lurking around for a few weeks checking out various info's!) so hopefully someone can help me out/steer me right!
Anyhow, last week i picked up a 0806 (seller states it is v3 stock, i'd say at the very least its v2 if not v3 just due to what came in the box).
So for some reason the cam keeps locking up after it records for a little bit, usually 15mins>30mins it'll just freeze requiring a manual reset. Annoying thing is 9 times out of 10 the indicator lights will keep operating like its working fine (GPS/Charge on, Recording light blinking), only once you turn the screen on you'll see the video is "frozen" and no video is recorded after that. Very rarely on that 10th time it'll actually lock everything up or power off (all lights stay on or just goes completely off) and when i reset it, the first time i power it on it'll do nothing (no sounds/black screen/etc) but will show the Red LED solid on and freeze, then i hold the button for 20 secs again, after that it'll power straight on no problems (until it freezes again)
If i attempt to "stop" the recording it just sits there with the spinning circle in the middle of the screen until i reset it.
This didn't occur immediately out of the box, it recorded perfectly for 2 or 3 days but then around the time i flashed the latest firmware to it it started doing this. I've tried flashing a few different firmware versions to the cam (the latest one actually seems to make the cam freeze faster/more often than older versions?) but they all lock up now (even after resetting to default settings on my original firmware version!)
I've tried 2 SD cards (one 8Gb and one 32Gb, both sandisk, both class 10, both check fine on the PC with h2testw). Cam is hardwired to the car but also craps out using the cig light plugs or even just connected to a USB charger/pc and left recording on the desk.....
I don't use 2 cards at once (i read about that issue) but i have tried both A and B slots and set the camera to record to A or B not Auto.
My cam does get a little warm but i'd hardly say it was hot (not hot enough where i'd usually think "uh oh somethings wrong") after an hour of being on.
I've also noticed it dumps error log files to my SDcard when it craps out.
Does this sound like a bad camera? Is there anything i can do (settings on the cam/specific firmware) or should i start the painful process of warranty (luckily i bought from a local aussie ebay seller exactly for this reason).
Cheers!
Cheers!
