doublediamond
- Aug 19, 2017
Can anybody come up for an answer to this? When I play my clips on my L/T it starts playing the last recorded clip first, then the second from last second and so on, this means that the start of a clip is not following on from the last clip, think about it . It should start at the oldest clip first so as to play all the clips in sequence and then everything looks correctly as in a movie. If make a folder on the L/T , "select all" on the sd card and drag and load the clips to the folder, everything sorts itself out, the first clip in the folder is the oldest clip an everything runs in order, as it was filmed. I have three 119 cams and one 119S this happens on all cams, I have tried lots of different cards, all react the same. I use the 119S as security on motion sensor set on 400ms, a 128gb card will last about 5 days, as other people have found it does not over rite when card is full. Works great with the street lite and is in color.
