MattW711
Hey, I am currently trying to hardwire my Mivue dashcam into to my 2017 mazda 3 however through online reviews and checking with a volt meter i have found that all mazda 3’s interior fuses are constant (always supplying power even when the vehicle is off). With this in mind the Mivue hardwire kit has a ground and battery wire which i can both install without issue, however the ACC wire cannot be put in as i don’t have a non-constant fuse to plug it into, I assume the ACC is not for supplying power but to send signals to the dashcam for when ACC power turns off and on. I have seen other hardwiring kits from other companies that don’t have the ACC cord however if i used one of these kits without ACC, would this mean I could not use parking mode?? I know there are non-constants in the main main box however i want to avoid going down that path. If anyone has any idea about this it would be much appreciated! Thanks.
