rcg530
- Jan 23, 2021
- California
- BlackVue, Thinkware, VIOFO, Vantrue, Blueskysea, FineVu
70mai sent me a test/review sample of their new 7500 mAh (96 Wh) Lithium Iron Phosphate (LiFePO4) battery pack. I've started testing this battery pack (limited tests so far).
Specifications listed on the box:
- Model: BL96NNX
- Nominal Voltage: 12.8V
- Rated Capacity: 7500 mAh
- Rated Energy: 96 wh
- Nominal Capacity: 7600 mAh
- Limited Charging Voltage: 14.6V
- DC Output (XT30): 11.2 - 14.2V 2A Max
- Type-C Output: 5V 2.4A Max
- DC Input: 11.2-30V 11A Max
- Charging Temperature: 0°C ~ 45°C (32°F ~ 113°F)
- Discharge Temperature: -10°C ~ 60°C (14°F ~ 140°F)
- Battery Type: LiFePO4
- Storage Temperature: -10°C ~ 60°C (14°F ~ 140°F)
- Max Cigarette Lighter Power Adapter Charging Amps: 7 Amps
- Charging Time: 90 minutes
- The CLA charging cable is not included in the box (optional accessory)
- Max Fuse Box Charging Amps: 11 Amps
- Charging Time: 60 minutes
- After 2000 complete charge/discharge cycles
- Battery retains 70% of its original capacity
- 22 CM x 12 CM x 3.5 CM (8.67" x 4.72" x 1.38")
- Battery Pack
- Fuse box charging cable
- Parking surveillance cable adapter
- 3-wire cable that is to be spliced with dash camera's hardwire cable/adapter/kit
- Each wire also has a 1-wire lever connector nut [no soldering required]
- Type-C to Type-C output power cable
- Four fuse taps
- Four 20A fuses [one for each fuse tap type]
- Cable ties
- The box I received only contained one Velcro cable tie
- Two Velcro tape strips
- Can be used to secure the battery pack to the installation location
- User manual
- Charging Power Choice
- Hardwire vs Cigarette Lighter Adapter (CLA) - Purchase Time Decision
- The battery pack comes with one charging cable based on your purchased time decision.
- Hardwire Charging Cable
- Stated charging time from 0% to 100% is approx 60 minutes
- The charging cable contains 16 AWG wires.
- The installer is expected to source the constant (VCC) power supplied to the battery pack from a fuse tap
- Four different fuse tap types are provided in the box - each having a 20 Amp fuse installed in the accessory device (top) fuse slot
- The battery pack is rated at a max of 11 Amps, so the 20 Amp fuse seems too high of an amp rating (15 amp would be sufficient)
- Adding a 11 amp load to a pre-existing fuse box circuit may be overtaxing the wiring providing power to the fuse box fuse socket if the pre-existing item(s) powered by that fuse box fuse socket are consuming a vast majority of the current capacity of the circuit.
- The installer is told to wrap the accessory power sense wire (ACC) around a leg of the fuse in the fuse box (major fail!)
- You never wrap a wire around a fuse leg since it my expand the contacts in the fuse box fuse socket (major fail!).
- The installer may not select the side of the fuse box fuse socket that will be protected by the fuse (major fail!).
- There should be another fuse tap provided in the box for the ACC wire to be properly installed into the fuse box.
- CLA charging cable
- Stated charging time from 0% to 100% is approx 90 minutes
- Vehicle's Cigarette lighter (power) port must provide switched power
- The vehicle's power port must turn off the power to this port when the vehicle's ignition is turned off.
- Switching from "Fuse Box" charging to "CLA Charging"
- There is a process identified on page 5 of the user manual that you must perform to "unlock" the battery pack so that the battery pack can be successfully charged using the CLA charging cable.
- Multiple references to XT30 connectors when the battery pack uses MR30 connectors
- There are multiple places in the product documentation that states the battery pack has XT30 connectors.
- It actually has MR30 connectors.
- First Time Charging Test - Fuse box charging cable option
- I used a DC power supply set to 14.2V with a maximum of 10.2 A (max for the DC power supply)
- The evening before the test, the battery pack had been fully discharged using a DROK USB load tester
- Maximum Amp Draw
- Charging Progress
- Start
- First power sent to dash camera
- Approx 20 second delay before charging starts
- 25% Charge Level
- 50% Charge Level
- 75% Charge Level
- 100% Charge Level
