- Sep 29, 2015
- Shenzhen
- China
- A129 Pro / A129 Duo / A119 V3 / A119S / G1W-S / WR1/
Sometimes the files may be broken and are not playable on the computer. For example, if you remove the SD card while recording, the file is not saved successfully and you can not play the file.
Instead of using some tool to repair the video, there is a easy way to solve it.
Just go to playback mode, the file will be automatically repaired and you can play the file in the camera, then you can also play the file on computer.
