Gibson99
- Jun 20, 2014
- Houston, we've had a problem, Texas
- Yes
no actually a format alone won't. check some of the other threads here. the way it works is the manufacturer can set a bit in the header of the card (probably not the proper term, but you get the idea) so when the operating system asks the card now big it is, it can say anything from 4 megs to 512gb. these fake cards lie and say they're 32 or 64 or whatever when in actuality there might only be 2gb of usable space on the card. windows only writes the FAT in the first few blocks which are rarely ever bad, and then it seems fine. only way to know for sure is to specifically write to every block and try to read it back. this is because windows 7, 8.x and 10 know not to do an actual full format on any solid state media (ssd drives, usb drives, flash memory, etc) so it doesnt cause premature wear. instead it uses the TRIM command for cleanup. macos does the same. h2testw and others bypass that and give you a proper, full test of the media.Well formatting on the computer will let you know if it's authentic card or not if you bought a new card... and then format it in the camera afterwards.
