A118c low battery
volksjagger
Hello,
Just got a new A118c (with capacitor instead of battery) and when I plug into the computer with the supplied usb it gives me a low battery error and shuts down about 20 seconds later, unless I put in "mass storage" immediately. But that does not allow me to manipulate the settings for time/date, resolution etc.
Nor do I think I would be able to update the firmware which is probably out of date since the default time stamp says 2/15/2015 on the videos from today. It does power up and work fine in the car but it seems like I should be able to sit in the house and play with the settings etc.
BTW I am also powering the device in the car via a usb cable with a 3 port usb charger and not the provided car charger as it would take up the only spot to charge phones.
Any feedback would be appreciated. I am a novice for sure.
OK thank you for that information about the laptop power issue.
I found a workaround for in the house.
I plugged the camera via the supplied usb cable into my iPhone usb wall outlet adapter for charging and that works also.
I also found that one of those cell phone charging doodads works well without having to be close to a power outlet. Came in handy when I was doing the initial setup in the vehicle and hadn't hooked up power to the vehicle yet.
