A118C
Puppie
Sorry but please bare with me... new to DashCam.
Bought a A118c fro Gearbest but the manual is VERY limited... and hoping someone can help me.
After you start the car and the dashcam comes on, how do you put it into standby mode? ; and
When the car is running there's a red 'dot' on the top left that's blinking (inside the screen) but the rec indicator isn't blinking, which according to the manual.. need to be flashing to indicate it's recording.
if I press on the 'rec' button.. that rec indicator will start flashing and the rec timer will start but it still stop again after 50sec.
Sorry - wish I didn't have to ask these but the instruction manual is really.. crap.
Should start recording automatically when power is applied. Pressing the record button stops recording and places into standby. Press record again restarts recording
right, it's a little counterintuitive between the red dot on the screen and the red REC light.
when you first turn it on by starting the car, the red dot and REC light will start flashing to indicate that it's recording
if you press REC it stops recording. the red dot goes away and the REC light stops flashing and stays on solid - this is the counterintuitive part for me. i think when you stop recording, the REC light should go completely off, but that's not how it works.
press REC button again and red dot starts flashing and so does the REC light.
one other thing you mention it stops after 50 seconds. do you see any blue error messages come up when it stops? maybe your memory card is bad? you can run h2testw to make sure your card is good. make sure the G sensor and motion detection are both turned off as both are buggy on this model and can cause all sorts of weird issues. also make sure you have loop time set to either 1 3 or 5 minutes. if you turn loop off, it will just record till the memory card is full then stop recording and turn off. not very useful for standard dashcam usage, but i have personally used that function (loop off) to record an entire 2000 mile road trip (required swapping in a spare blank memory card, and dumping the memory cards to an external hard drive using my laptop each night).
have you got motion detect on?
Thanks heaps for the replies.!
I do have motion detection on as that was one of the reason I got the A118c - to catch anyone that back into my car and then drive away as it seems to be a common practice here. I failed to mentioned I've got it hardwired via a Powermagic Pro - that should not screw it up, should it?
Didn't know motion detect is buggy so I will turn it off and see if that works. I do have it on but this weirdness is happening when I am driving.. thus the motion should be kicking in and recording.
I have kept the loop timer and all settings as default..
You right about the counter intuitive thing - damn confusing and all. No error - after 50sec, it just stop.
Have turned the motion detection off and G-sensor off and see it is will work; so far so good. =) Should have just paid a little more and got something more decent..
Yeah it will stop recording while driving because it doesn't detect motion from the hood/bonnet. And while parked it won't start recording till several seconds after the event you probably wanted to capture.
I have a cf100 in my wife's car, which has 2 cameras and proper motion detection and parking mode. That was prompted after two different hit n runs in church parking lots. Grrr...
Ya - so far has had 2 hit and run on my front; I initially though the battery capacitor means there's a mini battery inside that will prompt it to start when it detects shock.. that mistake made me bought a PowerMagic Pro.
Should be ok now I hope.. with what I've learn here.. have tweaked it and see if it'll do what I need it to do. But at less than $100; I guess you get what you paid for.. =)
Not a total waste. The a118(c) is a good cam for recording while driving. You can use the pmp on other cameras like the cf100 that do have a proper parking mode.
