UserDashCam
Hi,
for more than a year I'm owner of A129 Plus 2ch and I was satisfied with everything but low light picture.
Now I bought A139 Pro 2 ch and installed it on the same place that I had A129 Plus before. My experience is negative. I was more satisfied with A129 Plus than A139 Pro. If I would not need to replace cable to back camera, I would put A129 Plus back.
My issues with this camera (tested with and without HDR, always maximum bit-rate, also upgraded with last firmware from official page):
1.) Very bad GPS signal.
I mounted front camera on the same place that I had A129 Plus (which got GPS lock in cca. 10-20s after start). New A139 Pro takes few minutes to get GPS lock. After that it show speed OK for few minutes and then speed is completely wrong. Driving through woods or very short tunnel (cca. 50-100m) looses signal again for few minutes. I have mounted it on the top middle part of windshield directly under darker part beside rear mirror.
Is this known issue?
2.) Very bad motion blur
I'm very disappointed with motion blur of new A139 Pro main front camera. If the weather is not sunny (clouds, fog) or at mornings/evenings you can not read licence plate of car driving to you even if both cars go cca. 45 kph (cca. 25 mph). Every frame has blurry license plate. On regional roads there is no way to read license plates if it is not middle of sunny day.
A129 Plus has no issue with readable license plates at same conditions.
3.) Main unit gets hot
After 1h drive on cloudy day (no direct sun) with temperatures around 10 deg C (50 deg F) main unit was pretty warm / much hotter than A129 Plus. I'm a bit worry how this unit will work in summer on direct sun.
Does anyone uses this camera in hotter weather? Is it OK or are there any issues regarding temperatures?
Thank you for answers.
