hasko
My A139Pro is connected to always-on OBD adapter and was working fine since day 1 using stock usb-c cable that comes with the package. The parking mode worked fine as it entered after 5 mins.
However it stopped entering parking mode after I decided to change the stock usb-c cable into new fast charge usb-c cable (the reason is I need L-shape usb-c ).
everything else is working fine. The camera just keep recording 24 hrs non-stop in normal mode. G-sensor is working fine - it locked video when shaking. Wifi is also working fine both normal and station mode.
I'm not sure if there is any special wiring with Viofo usb-c cable or not but the parking mode came back when I changed the cable back to Viofo's.
Does anyone has explanation over this behavior?
If my guess is correct and Viofo does have special wiring then will A229 cable work with A139 Pro? or any other cable that would be compatible ?
I really need L-shaped cable for my installation.
