sduser
- Nov 11, 2023
- US
- Viofo A229 Plus 2Ch, A139 3Ch, A229 Duo 2Ch, A139 v3
I am installing a Viofo HK4 for my A229 Plus 2-channel dash camera and finding the setup does not work the way I expect it to. Wondering if I am doing something wrong or if I have a defective part.
Using multimeter, located two fuses to use with HK4, one that always provided 12V regardless of ignition state (call this PWR), and another that only provided power when ignition was in the ACC or ON state. I confirmed expected voltage of these two fuses in the OFF, ACC and ON ignition states.
Connected HK4 red wire to PWR fuse using a Bussmann BP/HHLP-RP add-a-fuse (is orientation important?).
Connected HK4 yellow wire to ACC fuse using a Bussmann BP/HHLP-RP add-a-fuse (is orientation important?).
Connected black wire to chassis ground.
I configured the camera for 3 LEDs during regular mode recording, and 1 LED (power only) during parking mode recording.
I would expect for the camera to be off initially, then enter regular mode recording (3 LEDs and no parking mode icon) when ignition is turned on, then enter parking mode recording (1 LED and parking mode icon) when ignition is turned off.
That is not the behavior I observed so I tested various ignition, wiring and configuration states.
Operation Matrix:
![1699745661726.png 1699745661726.png](https://dashcamtalk.com/forum/data/attachments/68/68881-e8b1d8720476c28d2aada3cb866a66be.jpg?hash=6LHYcgR2wo)
unexpected behavior:
camera operates in regular mode recording when parking mode is disabled and ignition is off.
camera operates in parking mode recording when parking mode is enabled regardless of ignition state.
the camera does not switch between regular mode recording and parking mode recording as expected when ignition state is changed.
Any ideas? Has anyone else experienced unusual behavior like this?
Thanks in advance.
Operation Matrix:
Thanks in advance.
