Yes I’ve tried powering it up with and without an sd card. The power light stays solid but the screen is black.Is there an SD card inside? Try removing it and attempt to power it on again.
Sent from my SM-X900 using Tapatalk
From the first day of use it is connected through the GPS module.Not sure if the camera is fully working with the USB Port you're using. Did you try to power the cam via the "GPS" USB-Socket?
