Power is supplied to the cigarette plug after the vehicle is shut off. But for how long depends on what the battery monitoring system thinks of the battery's health / remaining life.
I actually prefer not using parking mode because of where I have the 3rd camera mounted facing the driver's side window. This is in case I get stopped by a cop, I want it to record regular video with audio, even if I shut off the ignition.
Well now that I know your specific use case it changes my original troubleshooting recommendation, and I came up with a different solution.
1.) Dash cam must start recording with engine start up.
2.) Dash cam must continue to record in NORMAL RECORDING MODE, (not parking mode) when the engine is shut off long enough to capture a potential traffic stop.
I’m positive you will not take my silly recommendation but, I’m hoping it will spark your imagination for a solution that will work for your specific application.
Obviously your vehicle has the majority of blame for this malfunction because the vehicle’s computer controls the cigarette lighter / power port.
My “easy plug & play” suggestion is to isolate the dash cam from your vehicle’s electrical system with a cheap $20 (Li-ion / Li-polymer) Power Bank that has pass through charging.
These are the type of Power Banks that should never be left operating in a hot parked car because they may explode, and burn your car down.
If you want to eliminate the possibility of explosion, and car fire you will need to step up to LiFePO4 (lithium iron phosphate).
1.) Connect original included Viofo USB power cable to the Power Bank to operate the dash cam.
2.) Connect the power bank to the cigarette lighter / power port of your vehicle.
When you start the vehicle’s engine the power bank will;
1.) Turn on, and begin charging
2.) Turn on dash cam to begin recording
When you shut the vehicle’s engine off, the dash cam will continue to operate in NORMAL RECORDING MODE until the power bank is dead.
For reference a 20,000mAh power bank is 74Wh.
74Wh ÷ 8 Watts (A229 Pro 3-CH) = 9.25 Hours of operation.
I have another option but it is not “easy plug & play”.
It involves installing a relay, modifying your cigarette lighter / power point electrical wiring, and adding a push button switch to your dash.
What do you think?
-Chuck
