a329s ssd problem
jello1717
taiwan
Taiwan, Province Of China
What SSD models does everyone use?and where do you place them in your car I’m currently using the Micron X9 PRO and an MX500 in an external enclosure. After connecting them to the A329S, the car's GPS cannot receive any signal at all—aside from my phone, everything else fails to function.
By the way, I'm using the official VIOFO SSD connection cable to hook up the SSD, and even so, my GPS still doesn’t work. The A229 Pro next to the A329S also can't receive any GPS signal.
Are you connecting the SSD to the correct USB-C port on the SIDE of the dashcam? Not the one in the mount?
Also - the GPS module is in the removable mount, so make sure it's clipped into the mount when you're testing, otherwise you won't get any GPS signal at all.
Regarding compatible drives, check out this thread;
Did you ever find a solution to your problem? I have a SanDisk extreme but with the same issue. Found when I disconnected the cable from the side port, everything was fine...GPS connected. I thought it was a shielding issue with the cable...tried 2 different VIOFO ssd usb cables...neither even recognized the ssd. Other cables did, but then no connection with the GPS. Start8ng to think it's a faulty main a329 unit.
I have the samsung T-7 Shield 2 TB and have been using it without issue for a few months. I have it in 3 cars. I have issues with the new firmware and my SD card error but not with the SSD drive. The SSD drive works well. I have seen people complain about the 4tb T-7.
This is what VIOFO originally recommended. I understand that they are no longer recommending the samsung, but I have not had issues with it so far.
