Steviejones133
Hi all - total newbie here on these forums!
I recently bought the above dash cam for my Audi TT mk2 2007 and I also bought the manufacturer hardwire kit as well. Links below!
Dash cam:
Hardwire kit
Obviously the hardwire kit includes fuse taps to connect to the fuse box at the end of my dashboard, but I’m not entirely sure which fuses I should tap off? - obviously not critical circuits like ABS or airbags etc and I have read that as I need constant and a switched/accessory feeds, circuits such as the cigarette lighter socket fuse is good for accessory power and the radio is good for constant.
With my limited electrical knowledge, I have tried to test these two circuits.
The cigarette socket only works with the key in ignition to accessory position.
The fuse for my radio, I’ve had the car locked and alarmed with windows down to see if I could power up the radio after a few hours and yes, the radio works even when the car is locked and alarmed.
So, my questions are;
Is it safe to assume that these two fuses (both 10a) are safe to use for constant & accessory power? The fuses in the taps are 2a.
Fuse tap orientation - this is a picture of someone else’s TT fuse box where I’d be tapping from - fuses 38 for accessory and 34 for navigation/sound system. Would all the fuses have the same orientation?
If I’ve missed anything out, just let me know, but I could really do with some advice on this and confirmation of which fuses to use etc.
Huge thanks in advance of any reply
Regards
Steve.
Dash cam:
NEW- Road Angel Halo View 2 Rear View Mirror and Dash Cam with 10" Touch Screen & Dual Parking Mode - USB Type C
Alert Types / Extras Parking Aid - Reverse Trigger - Winter Mode - True Parking Mode Recording Resolution 2K 1440p & 1080p rear Viewing Angle 140oC & Rear 120oC Memory Up to 128gb external microSD Sound Optional Recording Connectivity Mini USB Image Sensor Omnivision OV04B10 & Rear GC2053...
www.roadangelgroup.com
Hardwire kit
HWK5VIEW - Road Angel Halo Dash Cam Hardwiring Kit - for Halo View / Halo Vision
Our Road Angel Halo Hardwire Kit makes it easy for anyone to install our dash cameras in any vehicle, no matter the make or model. Our system allows for simple plug and play accessibility, and contains everything you need to get started. Our dash cam hardwire kit allows for a quick and easy...
Regards
Steve.
