thank you for all the suggestions, how do you compare A119 with A229, is it worth upgrading?
Read the forms here, watch and compare the footage users provide, watch Youtube videos etc...
The A229 plus/pro series is not out (fully) yet it seems, it is new model and is still being tested by reviewers and still being refined before it hits retailers other than from VIOFO direct.
The higher models, like the A229, support multi cams (multi-channel) so if you want front (main), rear, interior, for example, those are what those models do.
A229 Plus/Pro also is 4K resolution for the front main cam, vs the 2K (1440P) of the A119 Mini 2.
It is also much larger in physical size, than the A119 Mini 2.
The standard A229 is 2K, but is using the 1st Gen Sony Starvis sensor, which is not as good as the 2nd gen in the Mini 2.
The newest models of VIOFO cams have the Sony
Starvis 2 sensor, which is the most superior sensor at this time.
The older models are just Starvis (1 st gen), so that is a key point to look for if you are looking around at the various models they offer.
EDIT: Edited to clarify the A229 Plus/Pro is 4K camera.... looks like the plain A229 is 2K with 1st Gen Starvis sensor.
