Audio fade
soulreapersteve
Hello!
First off, I would like to say I've been mostly enjoying the past 2 days of dashcam ownership. Along with my radar detector, it makes driving a bit less worrisome.
As the title indicates, I've encountered an issue regarding audio fading in and out with the recordings. Sometimes, you can clearly hear the music playing along with the car's engine/exhaust and other times, you can't. Also, it seems to switch between sound "sources" (for the lack of a better word). For example, you can either hear the music playing or the car's engine/exhaust. This happens on both local playback and youtube.
Secondly, the video seems a tiny bit "choppy/pixelated" on both local playback and on youtube - more noticeable on youtube. I've seen videos from others where quality is amazing; I can clearly read license plates and no choppiness/pixalation.
So my question is, what could possibly cause these issues? I've made sure the cam is firmly mounted in place, windows and lens are clean, and the version of the cam's software is SG20151109.V2 - which I think is the most up to date version.
Other than these issues, the dashcam is amazing! Very small form factor, plenty of accessories, and is very easy to use/install. I've shown a few video samples to people and they stated high interest in the GC!
Here's a link to the video. If needed, I can upload more samples. Please let me know if it doesn't work, I marked it as unlisted.
Thank you in advance!
It appears audio is clear when car engine revs are constant. As soon as you hit accelerator the sound starts fading. Probably unit sound recording processing tries to balance between additional surrounding low frequency and in-car music.
can you provide an original source clip for us to check, if you can upload to somewhere like www.mega.co.nz or dropbox etc so we can check, YouTube is ok for a basic idea but they re-encode the video so always best to have an original clip to check
which memory card are you using, make and model?
have you installed the EVA foam bad on the back of the mount?
I think @niko is on the right track.
Without knowing anything at all about the internals of the GC based on your video and my own I would suspect the audio circuitry is designed with ALC (automatic level control). Basically what that does is try to record the volume at a constant level. As the engine/road noise level increases it becomes the primary audio source - when it drops the radio output becomes the primary audio being recorded. If you were to start yelling at other drivers I'm betting your voice would become primary. 😉
IMO it's normal.
resonant frequency can affect the sound, the EVA pad on the mount can help a lot in some situations
I'm sure there are a lot of things that can and do affect audio recording.
In my case specifically my car has a feature called ANC (automatic noise cancellation). It consists of a number (3 I think) of microphones throughout the interior that monitor low frequency ambient noise (wind noise, tire noise, etc.) and generate 'counter-noise' through the audio system and they effectively cancel one another out.
What I've found in practice is for me sitting in the passenger compartment it works very well in that I don't hear a great deal of the targeted sounds (wind, tire, etc.). However when I play back some of the video I've captured there's almost always a bit of noise recorded (it sounds like a low 'rumble' or 'hiss'). It took me a bit to figure out what was happening and I've concluded it's a matter of microphone and speaker location. The vehicle is sampling the ambient noise throughout the cabin and the GC is recording from a fixed location. The vehicle generates the counter noise through the audio system speakers and three of the speakers are in the dash directly below the GC. Therefore the GC is recording the generated 'counter noise' that I'm not even hearing.
You raise a good point, quite a few cars have this functionality these days, some also add some sounds as well to transfer engine type sounds to the interior of the vehicle, something we need to consider
Don't misconstrue my comment, it was not intended as a complaint or something that needs to be addressed. It's just a matter of 'it is what it is'.
Took a bit of research to figure it out (moving the camera around the cabin while recording on the road, powering with an external source, etc.) to find the pattern. You can probably do a lot in the F/W but I don't think the defying the laws of physics would be one of them. 😀
FWIW my A118-C cameras do the same thing insofar as picking up the counter noise.
no problem, knew exactly where you were coming from
this is what I was referring to as the added sound
Thanks for the awesome replies everyone!
Memory card is the one that came with the package, Transcend Premium 400x 32GB Class 10. Please let me know if more samples are needed, I have plenty!
Also, I have done tests with and without the EVA foam pad. The sound fluctuations still occur, just not as noticeable.
https://www.dropbox.com/s/nedxwcqds...181008_098 (6-12-43 PM - 6-14-18 PM).MOV?dl=0
I have a Scion FRS, wish they had these features but it's a bare bones, back to 90's-basics sports car. No sound deadening, no ANC, and while they did include a sound tube to pipe in engine noise into the cabin, I plugged that thing up because it sounded like a wailing banshee. A lot of people hate the car because you can really hear everything. Videos don't pick up how loud it really is inside, especially if on sticky summer tires.
All in all, if this sound fluctuation is normal, then I'll stop worrying. I'll see about the video quality part by testing out the other SD card I bought, 128 GB PNY.
