bad batch?
hpad06
I got A118 from foxoffer , received it today. firmware version is 20141027
I plug it in a usb charger, and start testing it. It works fine for about 10 minutes, then keep rebooting.
Is this hardware problem?
I purchased the same model from gearbest 2 months ago, that A118 is still very stable, no issue so far. Should I return this to foxoffer and buy from gearbest again? Is it possible gearbest's new batch will have the same problem?
Thanks ! Does billknow work for foxoffer?
Comparing with my working A118 from gearbest, this A118 from foxoffer displays number 8888888 in the top center screen. Also it does not power on without cable attached, it shuts off right away when unplugged.
Thinking the 20141027 firmware might be faulty, I tried to replace the firmware with 0821 found on dashcamtalk , and it appears it is also provided by foxoffer.
After the upgrade, A118 does not reboot anymore, however it does not record either. Only power button works, the other buttons do not respond. So 0821 firmware is not compatible with this A118 anymore.
There have been quite a few from Gearbest with issues too like they won't come out of USB Mass Storage mode when connected to just power sources - maybe one of the factories has dropped a clanger in manufacturing as well but like Jokiin says there are multiple versions of the hardware now and the same firmware doesn't work on them all.
It's like Seezeus have been manufacturing them!
a lot of domestic market stuff is bought by small traders, they never see the customer again so don't waste money on things like independant QC etc
Now I get another firmware from foxoffer, which is 20140917, it seems have fixed the problem. I tried it with over an hour, no issue so far.
