Best parking mode
Mjukes
London
Hi,
So I have my A129 pro duo set to low sensitivity when in parking mode, but it seems to be recording almost all the time. What is the best option so it will recognise a bump or a knock, without running constantly?
Cheers
Mike
If you have motion detect on then YES most cameras will be too sensitive and trigger on motion easy.
If it is the G-sensor alone i dont get it, those dont use to be too sensitive at least not for when driving
Are you parked near a road where lorries and other big vehicles pass by ??
I personally use low bitrate parking mode, which record all the time, but that might be a less fortunate mode if you park a long time, i personally have a 3 hour timer set in the camera as it is only when i park out on the towm parking guard is needed.
So I have G-sensor set to high and motion sensor set to low
But it just fills the card with locked files so quickly and they’re just trees and things.
Should I turn motion off?
