Just installed this camera this weekend. Having some issues.
The rear camera video outputs keeps turning Green and Purple a short time after applying power to the main unit. The hatch is motorized so it's not slammed shut when closing it. I mention this because it's been stated that this can be a cause of this issue happening. It appears to happen on it's own after a few minutes. The rear camera coax is undamaged as far as I can tell and hasn't been bent sharply or anything during installation.
I'm also having a number of other issues.
1) The time is not correct. I've set the timezone to Los Angeles. When I do a timesync through the iOS or android app, it sets the time and reboots. It comes up about 7 hours and 59 minutes fast. If I pull the power and let it sit for a 5 minutes and reboot, it comes up 7 hours and 54 minutes fast. Not only is the time not being correctly set, but it appears the unit doesn't count the time when it's powered down.
This occurs even when the blue GPS light is locked solid. I'm in San Francisco, the same time zone as Los Angeles. I experimented by setting other time zones all around the world and it makes no difference. The time is always initially synced 8 hours fast and then just behind that after reboots minus the time the unit has been off.
Also, the accelerator sensitivity doesn't seem to work. I've set it to it's most sensitive and tapping the front camera or shutting the car door, or kicking the wheels or pushing on the car doesn't trigger E events ever.
