Hi all,
I'm new to the forum, and new to the C1. I'm using it as a dash cam. I like it very much, and soon it will become a permanent install in my vehicle.![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
I believe I've come across a bug. Please understand that I only have one sample, but I have tested it at length. I am, by profession, a systems engineer (EE/CpE) and have managed a software/hardware quality testing team for many years. So, therefore, I assign myself some measure of competence.
Given that there does not seem to be a complete and all-inclusive manual or other documentation on these cameras, I've had to glean information from this forum, 2kool4u.com, and Innovv's web page. It is very possible that I've missed some key documentation or lack the understanding of the intended behavior, and am wrongly reporting a bug. However, I feel very confident in the details of the behavior. It is repeatable and consistent.
Actually, there are, I believe, two bugs. One is more obviously an error, the other might be considered a feature.
I am using FW20140313
I have named them as follows:
After receiving the C1 as a Father's Day gift, I used the only microSD card that I had handy. It was a small Kingston 2GB. Everything seemed to be working fine during initial testing and experimenting. However, after my first commute to my office (35 minute drive), I observed both bugs. After several more days of driving and experimenting, I've reproduced the bugs many times, and have characterized the exact behavior.
The bugs are only seen when the C1 attempts to record more than the capacity of the microSD card. With a small microSD, the bugs are very annoying and troublesome. With a large card (16gb or larger) it is likely most users would not encounter the bugs.
In order to communicate clearly, here is a list of my terms and their definitions:
Car_cable
Recording_session
1. Description of Selective Looping
2. Description of Shutdown Failure
Summary
Old files from previous recording_sessions are deleted when looping is required, but when files from current recording_session are encountered, looping stops and the camera does not shut down gracefully when power is removed.
So, as you can understand, using a small microSD card will trigger both of these bugs quickly. Using a large size card, the bugs would be very difficult to trigger, and might go unnoticed.
Permutations Tested
Recording_session 1:
Actual behavior
Recording_session 2:
Actual behavior
Recording_session 3:
Expected behavior
The shutdown_failure is likely a bug. I can't imagine that it was intended that the camera would stay awake and deplete the battery on purpose.
The selective_looping might be the intended behavior, depending on your perspective. One might think that you would not want to delete videos from the current recording_session. I did not expect this behavior, so I've thought this a bug.
Best regards!!!
- Selective Looping
- Shutdown Failure
Definitions
Car_cable
The USB to microUSB car adapter cable, which when used, triggers the C1 to automatically turn on and begin recording when power is applied; and to terminate recording and turn off when power is removed.
Recording_session
The single use event where the C1 is activated via the car_cable, records for a period of time, and then terminates gracefully.
Bug Description
Note that a 2GB microSD card holds around 18 minutes of video. After the card is full, I would have expected the C1 to delete the oldest file in order to make room for a new one. However, it only does this sometimes! This is why I call it Selective Looping.
The C1 does delete the oldest file, as long as the file was created during a previous recording_session. If the oldest file was created during the current recording_session, looping is terminated.
Once the Selective Looping bug is triggered and looping stops, the C1 no longer turns off gracefully when the car_cable power is removed. In fact, it shows a blinking red light (or sometimes, eventually, a solid red light) perpetually until the internal battery is depleted.
Summary
Permutations Tested
- three different microSD cards, from Kingston, Sony, and PNY.
- two different microSD card capacities, 2GB and 16GB.
- two different environments, in the car (hot temps), and at desk (cool temps).
- Formatted with C1 and with SDFormatter (full-erase)
How to Reproduce
- Installing a small microSD card is helpful, but not necessary.
- Calculate the expected capacity of the card in minutes.
- Initiate a recording_session by use of the car_cable.
- Wait longer than the calculated card capacity
- End recording_session by disconnecting power from car_cable.
Camera will end recording and turn off. Video files represent the most recent time that should have been recorded by the camera, for as much capacity as it has available.
Actual behavior
Camera remains alive and on, using battery power. Video files represent the first minutes that the camera was recording, up to the capacity of the SD card, but the most recent events (right before the camera was turned off) are not recorded.
- Using the same microSD card with the videos from recording_session
- End recording_session by disconnecting power from the car_cable.
Actual behavior
Camera remains alive and on, using battery power. Video files represent the first minutes that the camera was active in recording_session 2, up to the capacity of the SD card. The old vidoes from recording_session 1 were successfully deleted (looped over). The most recent events (right before the camera was turned off) are not recorded.
- Using the same microSD card with the videos from recording_session 2
- Wait less than the calculated card capacity (half of the time capacity is suggested)
Expected behavior
Camera will end recording and turn off. Video files represent the most recent time that should have been recorded by the camera, some from recording_session 2 and some from recording_session 3.
Actual behaviorAs expected!
Conclusion
Best regards!!!
