Camera Cabling Question
Lynn1953
North Alabama
I have a N2X and purchased a Dongar mirror tap. The Dongar came with short usb to usb-c cables. I also purchased short 90deg usb to usb-c cables off amzn. When using the cigarette lighter power source that came with the unit, I can power off the unit using the units power button. When using the aftermarket cables I can power off but it cycles back on within a few seconds. Has anyone encountered this or maybe know why it does this?
It is not recommended to use aftermarket power sources as manufacturers design their equipment to work with their specific hardware.
These taps for the overhead light / power are popular, just be aware Lynn that if the camera act funny it might be due to the alternative power supply and you should then test with the provided source at least just to confirm that.
I suppose the reason your camera come back on after turning it off is that it is on a circuit that is always on and not due to power starvation.
Data cables are not good for powering dashcams, they need decent charging cables to carry the fairly high power required for a camera.
Not being able to turn off is an unusual problem though, I can't think of a good explanation!
I was actually actually using a 12 v power bank ( the ones that are also used for jump starting a vehicle), it came with a 12 v lighter socket pigtail and its always on. I was using the vantrue supplied lighter plug in it and it was turning off at the camera but the plug was still hot as the light was still on on the vantrue plug. It also has a usb 5v out port aside from the lighter pigtail which i was using for the short non oem cables and its always on as well. I was wondering if there’s anything in the oem plug that knows you have switched the cam off but keeps the usb soocket located in the oem plug hot
No i dont think there is anything like that in the oem plug, generally the dashcams that will change to parking mode after a while of inactivity, they do so by not sensing any movement on the G-sensor.
There should not ab any comms going on that route with a dashcam, i think only now are we seeing the first inclinations of comms that side of a dashcam so hard wire kits will forward voltage to cameras, but i think the plan here is to use BT.
I forgot to mention the Dongar Power Tap for the mirror came with a short usb to usb-c cable which has the same result. Someone would think they would supply power capable cable but who knows.
Just checked - The oem cig plug is rated to output 2.4 amps, the short cables are rated at 2.4 amps. The 5v output plug on the the 12 jump bank is 2.1amp out and the 12 v socket on the same is 15amp out
