Camera Constantly Locks Files
cahriad
Every bump or knock locks the file. I have tried adjusting the sensitivity but no luck. Any thoughts on what may be the problem?
Hmm, that's extremely odd if you've adjusted the sensitivity.
Can we get a photo of how it's attached to your windscreen?
The camera is mounted using the supplied shoe. I have two other cameras that mount the same way and do not constantly lock file at the slightest road bump
Hmm, I think I he camera might need a reset. Hopefully estore009 will help with that
Reset the dashcam to see if it works or not!
Please download this tool here:
https://drive.google.com/open?id=1WcMO4W664dvM--CxoY0QMjMfmph3pBcG
Also, please load this BIN file from this link
https://drive.google.com/file/d/1SY9W1kx7jMn7pFl1MZGEfpVfz-a32Mlh/view
And then you can load it in this way: No need to insert a memory card into the camera unit, please note!
1) Keep pressing this button on the dashcam when plugging into the laptop USB socket.
2)Open this tool and select this "load bin file" section and load this bin file which lists in the second link.
3)Click this "start update"
In my old smooth riding car, the B1W g-sensor worked perfectly but in my rough-riding work truck it's hopeless, same as every other cam getting beat to death in there 🙄 It doesn't help that the roads here are in terrible condition 😡
When the conditions all line up against you as they've done with me, you may have to either get used to clearing the locked files frequently or turn the g-sensor off. I just clear the files regularly as that works better for me.
