my53rdchoice
- Mar 15, 2018
- United Kingdom
Hi
I have a NB 412GW bought from Maplin around 10 months ago.
Sandisk 32gb class 10 memory card bought from a branded physical shop (curry's etc)
It's hard wired into the vehicle and powered from a separate leisure battery so permanently on (battery is charged and no issues as it does other stuff)
Camera is not moved, touched or taken for months on end
Not had any problems at all till I updated the BIOS on Tuesday.
The issue I have is that at some point (after hours+) the cam stops recording
This has the double issue in that this activates the screen, disables the screen saver and then the camera is highly visible due to it's light which makes it a serious theft risk
(why the screen saver only kicks in when recording is just bizarre)
I can just start the recording the screen saver kicks in and then it's fine again for a bit
The settings are
1440P
2 mins vid
med g sensor
screen saver on
Auto Power Off
NBDVR412GWA-R12.4
as far as I know these are the settings I have used from day 1
Oddly, the camera is showing full battery but the second I pull the hard cable it turns off
Has the battery failed? Is this causing the issue?
Is it the BIOS? Is that coincidence?
Any other ideas why this is
As it stands it's under 12 month warranty for a few more weeks so will be binned if not resolved (2nd time I've had to activate the warrenty as the windscreen mount snapped internally after 4 months)
ta
The settings are
1440P
2 mins vid
med g sensor
screen saver on
Auto Power Off
NBDVR412GWA-R12.4
ta
