Porioti
I have a 2015 accord lx.
Can i use for constant power only the 5v fuse that comes with the viofo add on fuse tap in the empty moonroof slot? I don't have a moonroof
Where do i connect the switch/accessory cable? I have a fuse at the top that says accessory, it,'s empty but when car is off it still gives a reading.
Where should i connect this switch/accessory cable? I have an empty fuse with no marking 3rd from far right on 13, but i read that may not be a good idea.
Also, does it matter in which way i connect them, i read something about powerdraw, and that one end of fuse is a and the other b? Which way should the cable go when i connect the addon fuse to the left or the right?
Thanks a lot.
![7HNlR1N.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F7HNlR1N.jpg&hash=149ccee2dbb10e007e0e81ee6eab945c)
Thanks a lot.
