Elbeau
Is it possible to charge the B-130X at home and, if so, how? I don't see a port for the output end of a USB cable.
Yes, it is possible to charge the B-130X using the provided cigarette lighter adapter (CLA) and a AC-to-DC power supply. I tested the BlackboxMyCar 14.6V/8.0A AC-to-DC charger and that successfully charges the B-130X.Is it possible to charge the B-130X at home and, if so, how? I don't see a port for the output end of a USB cable.
Have you ever experimented with upping the input current on any battery pack when using an AC to DC adapter? I know the B-130X self sets its input current, but maybe with the other battery packs that have a High/Low option.Yes, it is possible to charge the B-130X using the provided cigarette lighter adapter (CLA) and a AC-to-DC power supply. I tested the BlackboxMyCar 14.6V/8.0A AC-to-DC charger and that successfully charges the B-130X.
7500 mAh / 96 Wh - BlackboxMyCar PowerCell 8 / BlackVue B-130X / Thinkware iVolt Xtra BAB-95
@rcg530 - In your video review of PC8 you show it drawing about 13.81 amps when set to 9. In your video about the heating of the coiled wire, it looks like it only hits a max of about 9.74 amps. Was there another change I'm missing? Yes, my original review of the PowerCell 8 did detect the...dashcamtalk.com
Hey no fair, you guys are hogging all the easy questions. LolIs it possible to charge the B-130X at home and, if so, how? I don't see a port for the output end of a USB cable.
I just thought of something.Have you ever experimented with upping the input current on any battery pack when using an AC to DC adapter? I know the B-130X self sets its input current, but maybe with the other battery packs that have a High/Low option.
I've got two different adapters from other brands, including one that outputs at 12V / 10A. In theory that should be fine to charge a battery pack at 9-10A in, but I don't know of the cig. lighter cable itself would be happy with the higher current load. The specs page for that adapter does suggest to not charge >120W for a long period of time though and these battery packs pull close to 135-140W at max load so maybe the lower speeds would be better afterall.Maybe I just answered my own question while thinking aloud, lol.
Right which makes it a bit easier to switch cables like this.I just thought of something.
If you are using the CLA adapter with the 3-pin connector, the B-130X will recognize that the CLA is being used, and not the hardwire charging cable.
Thus it will utilize the "low" 5 Amp charge protocol so it should not climb to the full 10 Amp capability of the AC/DC charger.
You're hurting my brain making me shift gears, and recalling my battery pack testing.Right which makes it a bit easier to switch cables like this.What if you tried it with a PC8 or iVolt Xtra and left the charge speed switch set to High? Those don’t autosense the input cable like the B-130x
haha not really. I’ve been working on my battery comparison for the past 2 weeks or so (hopefully done tomorrow!) so it’s all fresh. The A119 Mini 2 is on my WS collecting sample footage, but mentally I’m not there right now.You're hurting my brain making me shift gears, and recalling my battery pack testing.
Right now my brain is focused on A119 Mini 2 testing.
I'm so jealous of you, and RCG because you guys are so good at multitasking.
I'm only a "mono-tasker". lol
The PC8 does auto sense the XT60 connector type plugged into it. Even if you put the slide switch on "High" and plug in the CLA adapter with the third connector, the PC8 will restrict its charging to the 5-amp mode.Right which makes it a bit easier to switch cables like this.What if you tried it with a PC8 or iVolt Xtra and left the charge speed switch set to High? Those don’t autosense the input cable like the B-130x
I had no idea! Gotta take a closer look at those connectors now.The PC8 does auto sense the XT60 connector type plugged into it. Even it you put the slide switch on "High" and plug in the CLA adapter with the third connector, the PC8 will restrict its charging to the 5-amp mode.
The Thinkware iVolt Xtra BAB-95 does not have the third connection pin in its XT60 connector so it can't auto sense the type of plug that's been inserted into it.
I totally forgot about this. lolThe PC8 does auto sense the XT60 connector type plugged into it. Even it you put the slide switch on "High" and plug in the CLA adapter with the third connector, the PC8 will restrict its charging to the 5-amp mode.
