geekay46
Hi. New member here.
I've just upgraded to a new NextBase 322GW dash cam but am having trouble getting a wi-fi connection sorted on my Google Pixel 6 phone. I've been through so many discussions with similar problems.
I'm pretty sure it's nothing stupid I'm doing (probably is!!) as I have managed to connect my Samsung tablet perfectly.
The last thing I tried was to reconnect both of them side by side. I removed all traces of software from both tablet and phone and reverted 322 GW back to default telling it to forget everything from previous tries.
With the dash cam switched off, I installed the software on both phone and tablet and went through identical procedures on them both to set it up to the point where it tries to find a dash cam. I then powered off the phone and proceeded to connect the tablet which was 100% successful.
I then set dash cam back to default as before and powered off the tablet. Then I proceeded to try to connect the phone, this goes fine until I get the message "Wi-Fi Connection in Progress. Please wait. MyNextBase Connect will establish a High Speed Wi-Fi connection with your Dash Cam." Here it just hangs and hangs and hangs ..............
I know this all seems rather garbled, but I think it indicates that the software is working fine, I'm probably doing the right thing but something in the Google Pixel 6 is causing the problem. Has anyone managed to connect the app to a Pixel phone and if so has any idea what I may be doing wrong.
I am prepared to just use the tablet as that is working fine; however I don't like to be beaten!!
Many thanks
Many thanks
