Can't play back
Darren Robinson
Hi,
Bought 3 cams in total, for our vehicles, two worked straight away but the other, I had to turn off g sensing as it just kept filling the card then stopping. The problem is now my pc says it cant read the files, It did at first but now it cant, what am I doing wrong??
Hi,
Just formatted the card and I can see the first 5 min clip I recorded, just put in on for an hour to double check, It made me check my other cam and the card was full of Chinese labelled clips and files so I formatted that as well.
what brand name, size, class, type memory cards do you use ?
Sorry I have no idea it was ordered at the same time It does not say any make or class, but they were less than £5 if that helps.
D
D
no markings and the cheap price could well be a hint to where your problems lie, try a different memory card as a starting point
Yes I will, what class would or should I get?
What is the difference?, I have just tried again and some clips play, others not. When I go into properties of each clip, the ones that play have detail under the details tab, frames per second and length, the ones that do not play, are grayed out under the details tab
There are many good reliable memory cards that has been proven working fine with dashcams, but also there are some well known brand names that may work fine with mobiles / tablets etc., but not suitable for many dashcams ( hit and miss ). I have good experience with Transcend 300x and Lexar 300x ( and higher ) - series memory cards. Only thing to remember is to buy from reputable reseller to avoid getting fakes. MyMemory.com ( or their amazon and ebay store ) is where I would recommend to buy from.
to be sure, you can test your memory cards using H2TestW - link in my signature. that'll ltell you right away whether your cards are fakes. it sounds like they probably are, unfortunately.
you can get genuine cards pretty cheap on amazon - just make sure they're "fulfilled by amazon" so that if you get a fake/bad one, returns are easy. i got some 64gb samsung pro cards for about $20us each and have no problems with them. i tested w/ h2testw before ever using them just to verify, and they came back good. it can be a slow test, esp if your card is large (or claims to be) but it's thorough to be sure it's providing accurate results.
Thanks for the replies, it would seem that is my problem. I looked at the h2testw, but that was way over my head, couldn't work out what to do or even run it, but I will buy some branded cards.
Basically h2testw needs to format your card then it will start writing data to it, then verifying it on its own. This can take a while so you can do other stuff while it's working in the background - surf the web, get a cup of coffee, whatever.
Once it's done it gives a summary and as long as the written data is within a Meg or two of the read capacity, your fine. Most times when you have a fake card, there numbers aren't even remotely close... Fit example it may claim it wrote 64gb to the card but then it could only read 8gb. So that's an 8gb card that some unscrupulous seller modified to make the device think was 64gb.
