Cellink B parking problem
tigermad
Had my f770 and Cellink b working happily for 2 years and since Saturday parking mode no longer engages. It just beeps once when turned off. Could the piggybacked fuse have blown or is there another possible reason? The cellink has a green light so is fully charged. Thanks.
Maybe try this: Mine was one beep follow by 2 beep
Switch off on Cellink B
Unplug all wire from Cellink B
Wait about a minute
Switch Cellink B ON to 5V and push reset
You will hear beep sound after you release the reset
Switch to OFF cellink
Connect all your wire back
Switch to 7A if hardwired
It should work
Wait about a minute
It should work
I have the same problem as described on top.
I have tried your steps, but when i unplug all wire, the battery wont turn on at all.
It only turns on when cellink b is connected to car battery.
Fuses and wires seems all ok.
Does this mean the cellink b is broken?
Warranty expired 9 months ago.
