Hello,
I recently purchased a new Cellink Neo 8+S and a new Viofo A139 Pro 2CH.
I spliced the Cellink cable and HK3 cables together with some solder splice heat shrink tubes, and tested the cables by connecting everything up. It was to be installed in a new car which I hadn’t taken delivery of then.
I disconnected the cable, and stored it back in the box (still spliced).
A week later, I pick up the car, and when I tried to connect everything up, it no longer works. I tested the Cellink 12V output with the Viofo 12V connector and the dashcam powers on.
I resoldered the connection, once again the A139 didn’t turn on. I’ve got a spare hardwire kit for an A129, and tested it with an A129 from another car. Soldered the Cellink cable and A129 cable, and the A129 wouldn’t turn on. A129 works fine when connected through the 12V cable.
I got a new Cellink cable sent out, and unfortunately the same thing is still happening. Both A139 and A129 wouldn’t power on. I’ve reset the Cellink and the A139, and I’m currently waiting on a new HK3 to get delivered.
Not sure if there’s something else I should be doing? Weird how it worked initially, then after packing the cable back up for a week, it no longer works.
Any help is greatly appreciated, before I splurge AUD$150 on a pre spliced cable from BlackBoxMyCar.
Thanks!
Thanks!
