Gibson99
- Jun 20, 2014
- Houston, we've had a problem, Texas
- Yes
I had a hard time finding this so I'm posting it here for everyone to use. All credit goes to @niko.
The only thing I will add is that I tried to do the update using an old Crucial 2gb card, and it did not work. The camera turned on, then turned back off and did not do anything that Niko describes in step 7. I'm gonna try again using a 16gb card and I expect it will be fine.
FIRMWARE
Latest firmware / PC Viewer / User Manual you can find HERE
Instruction on "how to upgrade firmware" is HERE
1. Download the “CF100Update.tar” file
2. Format SD card
3. Put the downloaded file “CF100Update.tar” into the root of SD card
4. Connect rear camera before updating the device (before connecting power)
5. Insert SD card to the front camera and connect the power
6. Upgrade will start automatically (※It takes up to 5 min)
7. 2 LED on -> Blinking -> LED off -> The voice guide “Upgrade will be started” -> Blinking -> The voice guidance “Rebooting now” -> The voice guidance “Two channel recording is getting started”
8. Upgrade complete
P.S. - I realised strange "issue" after following an upgrade instruction. After firmware upgrade the rear camera was not recording. So, I disconnected rear camera, started main unit ( front camera ) and left it recording for about few minutes, then disconnected a power source. Waited 10-15 sec. Connected rear camera to main unit, started again CF-100 and rear camera was recording. I am not sure if it was some glitch, or maybe it's the right way to so called "reset the brain of dashcam" after firmware update, but just in case I am sharing this trick in case you will be in same situation like me.
