What does user manual says ?
Hi, in what respect?
Hi Will have to look when I get home but basically needs to be like the below but with a 3 pin plug. Needs to draw constant 6aIn respect to tech.specs needed to charge it. Usually this info should be listed in user manual.
You may find from this list
https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=Mains+cigarette+lighter
I think 10Amp will be good choice.
https://www.amazon.co.uk/gp/aw/d/B00PUNIEI2/ref=mp_s_a_1_1?ie=UTF8&qid=1491899869&sr=8-1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=Mains+cigarette+lighter&dpPl=1&dpID=51c1lridM+L&ref=plSrch
Or if you want to go with max 6A
https://www.amazon.co.uk/gp/B00PLR1OXO
The one we carry now is a 10A one, we found with ones that were rated up to 6A would get hot and stop charging the battery after about 20 minutes.
In other words, it is recommended to order the charger from blackboxmycar.ca
Not necessarily, we actually originally tested a unit from Canadian tire that seems to work well.
Hm.. Will the warranty be disqualified if other chargers were used to charge the Cellink B instead of charging it via the car? I don't think it will but I want to be sure.
Which model is that at Canadian Tire? And what is the BBMYC model?Not necessarily, we actually originally tested a unit from Canadian tire that seems to work well.
