Yes, the direction of the light source
absolutely affects the performance of a polarizing filter, especially when dealing with reflected light or phenomena like a blue sky.1
Here's why:
- Polarization of Light: Light waves oscillate in various directions.2 When light is "unpolarized" (like direct sunlight), its oscillations are random.3 However, when light reflects off non-metallic surfaces (like water, glass, or even leaves) or is scattered by particles in the atmosphere (like the blue light in the sky), it becomes partially polarized.4 This means a significant portion of the light waves will oscillate in a preferred direction.
- How Polarizers Work: A polarizing filter acts like a microscopic "fence."5 It has a polarization axis and only allows light waves that oscillate parallel to that axis to pass through, absorbing or blocking the waves oscillating in other directions.6
- Optimal Angle for Effect:
- Reflections/Glare: The most significant effect of a polarizing filter on reflections and glare occurs when the light source (e.g., the sun) is approximately 90 degrees (perpendicular) to your camera's line of sight. At this angle, the reflected light is often highly polarized horizontally. By rotating your polarizer, you can align its axis to block this horizontally polarized light, effectively reducing or eliminating glare and allowing you to see through surfaces like water or glass. If the light source is directly in front of or behind you, the polarizing effect on reflections will be minimal.
- Blue Sky: Similarly, the deep blue of the sky is due to scattered sunlight, which becomes polarized. The strongest polarizing effect on the sky (making it a deeper blue and making clouds stand out) is also achieved when the sun is 90 degrees to your shooting direction.7
- Uneven Effects with Wide-Angle Lenses: When using a wide-angle lens, different parts of the scene can have different angles relative to the sun. This can lead to uneven polarization effects, where one part of the sky might appear deeply polarized while another part is less affected, creating a patchy appearance.8
- Metallic Surfaces: It's important to note that light reflected off metallic surfaces is generally not polarized, so a polarizing filter will have little to no effect on reflections from metals.
In summary, for a polarizing filter to be effective in reducing glare, enhancing sky color, or increasing saturation, the direction of the light source relative to your camera and the reflective surface is crucial. You often need to rotate the filter to find the optimal orientation for the desired effect.9
