This is what I used:Thanks for the DIY! Just installed the Dash Cam 55 in my 2015 Camry and plan to add a CPL. What did you add between the 28mm step-up ring and the "gold" ring of the unit - my unit's lens diameter is 26mm, not 28mm? And where did you get the K&F Concept step-up ring?
When you have a minute, would you post some raw samples? I'd like to see how 55 is performing for other people.Thanks for the quick response! Will order when I get back in town.
Step up ring is made of aluminum so it was easy with Dremel tool.I see that the ring is made of metal, I assume stainless steel. What did you use to sand off the .5 mm to make it fit to the cam?
Thoughts on this: (model # MAG-OLYMPUS-26mm)
https://www.amazon.com/gp/B001N0W2SO
26MM and there are sellers on eBay claiming it's a direct ft for the Garmin Dash Cam 45 / 55 / 65..
For $14 I might just order it and see.
Any update on the MAG-OLYMPUS-26mm CPL for the garmin 55 dash cam?
