onceuponadashcam
- Jul 24, 2018
CPL lens has been received, the before and after video is below!
I expect to see more improvement than that, do your sunglasses remove all of the reflection off you windshield or are they partial too, maybe it is your windshield that is at the wrong angle...My sunglasses behave the exact same way.
It would be easier for us to judge the effectiveness of the CPL by showing a before & after video frame from the same scene when the car is not moving.CPL lens has been received, the before and after video is below!
Your screenshot looks like it has a small amount of vignetting in the bottom left corner too, so that's both left corners. I read in the other B1W CPL thread:My CPL also arrived today, testing it against my computer monitor it seems perfectly aligned, and also has good anti-reflection coatings. Compared to my mini 0906 CPL the image is significantly clearer. Also works nicely to remove the reflections off water, gets all of them if the angle is correct.
Fits nicely and looks good, seems well made - very impressed.
The only problem I have found is that if the camera is upside down then I loose the top left corner of the image:
Could the B1W's tapered sides account for the vignetting on one edge of your video?The polarizer appears to be machined symmetrical, however, the B1W is tapered toward the ends. This means that if you press the polarizer on all the way, it will sit crooked on the camera. Instead, to keep the filter glass parallel, you have to push it on straight until just the inner side makes contact, leaving a small gap on the outer side. Not a big deal, but perhaps the machining could be adjusted (different on the two sides) for future production to make installation more foolproof.
I think it sits flat against the front of the lens, so although there is a slight difference in the gap to the body, the gap to the lens front is zero all around - no problem.Your screenshot looks like it has a small amount of vignetting in the bottom left corner too, so that's both left corners. I read in the other B1W CPL thread:
I guess most people will buy the filter with the new camera, so the advice about removing the protective film from the lens before hiding it under the filter seems very wise.First time I've had a chance to compare 'with' & 'without' views since receiving the CPL filter a couple of days ago.
The first picture is 'without' and the second 'with' the CP filter fitted and clearly, the filter has taken away the dashboard reflections to a great extent. Situation was when the car was parked this morning.
One query - the small instruction card which came with the filter asks the user to remove the protective film from the lens. Am I assuming correctly that this refers to fitting the filter to a new B1W camera lens because the filter does not have a protective film. Or at least mine doesn't but my B1W lens had when new.
@estore009
I seem to have my B1W mounted too high up the windscreen and the filter doesn't remove the reflections from the bottom of the image due to the angle, works really well in the centre of the image though. I will have to move the camera before posting before and after images, but I am impressed with the results, one of the best CPLs I've encountered, seems to have really good anti-reflection coatings, and well made too with glass filter mounted in a very solid aluminium mount.
Finally got around to comparing my B1W with and without the CPL. Honestly I like it a lot since I do get noticeably less reflection/glare on the windshield. Below is a quick comparison video I took basically in direct sunlight.
